-= Topic Moved to Troubleshooting =-
@Arcuto
WHEN MAKING YOUR POST, ALWAYS:
  • Describe the problem you are having in detail but without rambling. If your post is as long as this one, it's too long.
  • Include your operating system including version and 32/64 bit.
  • Include your entire system specs, including the wattage of your PSU.
  • Tell us which BIOS version you have. Some problems can be fixed by updating to the latest BIOS, so check that there are no updates available
  • Include any software running when it crashes (if applicable)
  • Give full details of any error messages and screenshots if possible
  • Use an informative title briefly describing the error. It's not helpful to see a thread titled "please help" or "Urgent" because most people are better at some problems than others, so may not prioritize your issue, and some people will ignore you completely.
Without these details, we may not be able to help you. To speed up the process, please ensure you have all the details on your post.
 CHRISTIAN MEMBER
