If someone could help me fix this issue I am having and tell me what and why its causing this blue screen would be great help!
Recently, I have been getting blue screen and the error message that pops up is "Your PC has run into a problem and needs to restart". The stop code I receive is different but generally its "SYSTEM_SERVICE_EXCEPTION" or "UNEXPECTED_STORE_EXCEPTIONS".
I suspect that a particular steam game is causing my blue screens, Tekken 7. However, it only started doing this after the latest patch and has never happened in the 470 hours I have played it before. I suspect Tekken 7 is the culprit for my PC blue screening because it only crashes whenever I'm playing Tekken 7. I have not played Tekken 7 for 3 days and during that 3 days my PC has never blue screened and worked fine. Today, within the 30 minutes I have played Tekken I blue screened.
I have checked that my windows update is up to date, and my GPU drivers are the latest drivers released by Nvidia for my 2070 Super. Is there any fix to this problem other than not playing Tekken 7? (Which I will avoid in the meantime, but this shouldn't be a permanent solution).
https://linustechtips.com/topic/1215297-blue-screen-need-help/
14 minutes ago, RageTester said:
ERROR code starting with 0x would help locate the issue.
You can use this freeware to dig into dump files: http://www.nirsoft.net/utils/blue_screen_view.html
Sorry, there were no error codes shown on the blue screen. And nothing starting with 0x
https://linustechtips.com/topic/1215297-blue-screen-need-help/#findComment-13765229
