Hi!
I was hoping to get some of advice from anyone who can help me :?  I'm new to building computers and all my guy friends said I should build one instead of buy one. The problem I'm having is there is so many different version of the same exact thing >< I really don't know what I'm doing.
I have keyboard, mouse, and 2 1080p 23" monitors. I'm trying to build a gaming computer on a budget of about 1250 dollars U.S. I'm in Florida... and have prime and I don't know what else helps ><...
I've liked Nvidias and Intel in the past but alot of the builds here recommend AMD and Radeon... and I just don't know the difference well enough to make a real decision....
I understand how pc part picker works but outside of organizing it by reviews I don't know really how to tell whats best for the money :/
THANK YOU for any suggestions!!!!
https://linustechtips.com/topic/121525-advice-for-building/
CPU:  AMD FX-8350 4.0GHz 8-Core Processor  ($179.99 @ Amazon)
Motherboard:  Asus SABERTOOTH 990FX R2.0 ATX AM3+ Motherboard  ($177.69 @ Amazon)
Memory:  Kingston Beast 8GB (2 x 4GB) DDR3-1600 Memory  ($82.74 @ Amazon)
Storage:  Samsung 840 EVO 120GB 2.5" Solid State Disk  ($82.95 @ Amazon)
Video Card:  EVGA GeForce GTX 770 2GB Video Card  ($339.99 @ B&H)
Total: $1172.26
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-02-27 18:00 EST-0500)
Specs
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1617974
use a screw driver, spend an hour putting it together and 3 hours doing cable mangement. use zip ties, don't dry hump your carpet and then touch PC components.
http://pcpartpicker.com/
you will most likely use a 780 with an 8350 and 990FX board.
Error: 410
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1617976
Maybe this was the wrong place to get suggestions on where to begin building a computer, components, etc.... :/
Sorry I wasted your time......
As long you meet the three criteria stated above and select either an Hyper 212 evo or 240mm AIO, or high end air cooler the rest of the parts are mostly arbitrary.
You also need to wait more than 3 minutes, the forum isn't instant and paid tech support and consulting.
cba to do a build, a someone else will run along and give you one soon enough.
Also please quote or @username tag people, or they likely won't reply unless they follow.
Error: 410
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618002
It wasn't that it was the humping the carpet comment before you editted it to say anything of value.....made it feel like maybe I went into a boys club and I was just going to get a "go make a sandwich" crack instead of advice... :/ sorry for mis-reading your original post.
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618013
Total: $1172.26
Thank you for such a quick reply... I know I didn't give alot to go on... Is there a reason for the AMD over an intel chip or is it just budget :?
Just trying to have more knowledge then being so ill informed :/
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618030
It is a gender neutral hyperbole for avoid static discharge.
my location explains this phenomena.
budget.
price to performance is superior with an 83xx chip.
Error: 410
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618033
intels just over priced for the budget the amd 8350 gives my 4670k a run for my money in my opinion your still going to get amazing performance to price with it
Specs
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618041
Touch the computer case from time to time. Don't wanna Zap yourself OR your parts. Let me warn you now, as this is your first build, it will take a while to figure out what goes where. As for parts... it depends on your personal preference. I like intel and NVIDIA and that is what i rolled with. Honestly, it is what you think is better. Yeah, that is all I got.
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618042
budget.
Oh then sorry :/ never would have thought that was a reply.....
and ok that makes sense then for the price to performance :)
Thank you ^_^
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618057
Thank you ^_^
Vid1:
Vid2:
Vid3:
Watching these will help you immensly on how to pick out your parts and how to put them together. Even if you already have your build, watching them is still really informative, especially if you're just starting out.
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618082
Vid1:
Vid2:
Vid3:
Thank you! Videos are so much easier to understand ><
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618150
Type|Item|Price
**CPU** | [intel Core i5-4670K 3.4GHz Quad-Core Processor](http://pcpartpicker.com/part/intel-cpu-bx80646i54670k) | $179.99 @ Microcenter
**CPU Cooler** | [Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler](http://pcpartpicker.com/part/cooler-master-cpu-cooler-rr212e20pkr2) | $29.98 @ OutletPC
**Motherboard** | [Asus Z87-PRO ATX LGA1150 Motherboard](http://pcpartpicker.com/part/asus-motherboard-z87pro) | $134.99
**Memory** | [A-Data XPG V2 8GB (2 x 4GB) DDR3-1600 Memory](http://pcpartpicker.com/part/a-data-memory-ax3u1600w4g9dgv) | $77.98 @ Newegg
**Storage** | [samsung 840 EVO 120GB 2.5" Solid State Disk](http://pcpartpicker.com/part/samsung-internal-hard-drive-mz7te120bw) | $82.95 @ Amazon
**Storage** | [Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive](http://pcpartpicker.com/part/western-digital-internal-hard-drive-wd10ezex) | $59.98 @ OutletPC
**Video Card** | [EVGA GeForce GTX 780 3GB Video Card](http://pcpartpicker.com/part/evga-video-card-03gp43788kr) | $469.99
**Case** | [Corsair Vengeance C70 (Black) ATX Mid Tower Case](http://pcpartpicker.com/part/corsair-case-cc9011016ww) | $119.99 @ Newegg
**Case Fan** | [Corsair Air Series AF120 Quiet Edition (2-Pack) 39.9 CFM 120mm  Fans](http://pcpartpicker.com/part/corsair-case-fan-co9050002ww) | $26.99 @ Amazon
**Power Supply** | [Cooler Master V700 700W 80+ Gold Certified Fully-Modular ATX Power Supply](http://pcpartpicker.com/part/cooler-master-power-supply-rs700afbag1us) | $89.99 @ Newegg
**Optical Drive** | [Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer](http://pcpartpicker.com/part/asus-optical-drive-drw24b1stblkbas) | $19.98 @ OutletPC
 | | **Total**
 | Prices include shipping, taxes, and discounts when available. | $1292.81
 | Generated by PCPartPicker 2014-02-27 18:43 EST-0500 |
Here you go  :)
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618224
Type|Item|Price
 | | **Total**
Here you go  :)
Also If you have a microcenter near you you are golden
btw the 780 is from EVGA B-stock which is refurbished and comes with no accesories(you don't need them) but don't worry you get a one year warrenty and EVGA is known for its quality and customer service.
https://linustechtips.com/topic/121525-advice-for-building/#findComment-1618238
