so when i was swapping my parts to another board then booted it i noticed there was a light on the ez debug and it said it was the CPU so i checked it and it would immediately shut down after i push the power button. i unplug the cpu 8 pin and it turns on but the ez debug still says its the cpu. eventually i tried taking out the cpu and it worked with the cpu 8 pin plugged in but there was no display with the ez debug on the motherboard. please help me!
https://linustechtips.com/topic/1214731-pc-broke-need-help/
Specs ?
Clear the cmos
Inspect the cpu or the socket
Try with one stick at a time
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1214731-pc-broke-need-help/#findComment-13760800
