Installing an UPS
Go to solution Solved by gripfly,
Thanks for that. Meanwhile I found out that there is a Software to manage all that Eaton provides (well, actually 2).
There is Eaton Intelligent Power Protector (IPP) and Eaton Intelligent Power Manager (IPM).
The difference between these two can be read here: https://community.spiceworks.com/topic/1138829-difference-between-intelligent-power-manager-ipm-and-protector-ipp
There is a User's Guide for IPP, which is very helpful: https://www.eaton.com/content/dam/eaton/products/backup-power-ups-surge-it-power-distribution/power-management-software-connectivity/eaton-intelligent-power-protector/eaton-ipp-user-guide-p-164000291.pdf
After installing the Software you need to open the Web interface: https://localhost:4680/
Then login with; User: admin, PW, admin
This is all what's needed. Then you can manage all the stuff. However, I still have the issue that once the UPS shuts down the System, there is a connection failure afterwards. After about 2h the communication failure somehow resolves itself and it works again.
I made a post regarding this issue here (haven't gotten any response yet tho but if there will be ever an answer to this, it might be there): https://community.spiceworks.com/topic/2278555-eaton-5sc-communication-failure
Hi there
I just plugged in my UPS. However, it shows me that the battery is at 0%, plugged in and not charging. Unplugging the USB connection removes the battery widget. Do I need to enable something specific to make that widget work?
Thanks in advance.
Edit: I am running Kubuntu with an EATON UPS.
https://linustechtips.com/topic/1214281-installing-an-ups/
Hi,
sounds like your distro loaded / included apcupsd instead of nut for handling UPS.
apcupsd works great - for APC devices, but reporting zero values seems to be a common thing for some Eaton models.
You can find out if that's the case by the output of "sudo apcaccess". If it is present and displays the same wrong values, you're running apcupsd.
I've read that switching to "nut" (package "network UPS tools") shows better results with Eaton devices.
https://linustechtips.com/topic/1214281-installing-an-ups/#findComment-13762765
https://linustechtips.com/topic/1214281-installing-an-ups/#findComment-13765519
