Compact PC Build help
so I've finalized my build now. I'll be using the AIO as originally planned but ill have a Dark Rock Pro 4 available for a backup since it still fits while clearing the ram and I've added a rear fan for good measure but will tie it to VRM temps until i switch to air cooling. here's the build sheet
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor ($413.00 @ Amazon)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler ($89.90 @ Amazon)
CPU Cooler: Fractal Design Celsius+ S28 Dynamic X2 PWM 85.71 CFM Liquid CPU Cooler ($166.26 @ B&H)
Motherboard: Asus ROG Strix X570-E Gaming ATX AM4 Motherboard
Memory: G.Skill Trident Z RGB 16 GB (2 x 8 GB) DDR4-3200 CL14 Memory ($134.99 @ Newegg)
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive ($178.75 @ Amazon)
Storage: Western Digital Black 4 TB 3.5" 7200RPM Internal Hard Drive ($176.99 @ Amazon)
Video Card: MSI Radeon RX 5700 XT 8 GB GAMING X Video Card ($409.00 @ B&H)
Case: Fractal Design Define 7 Compact ATX Mid Tower Case ($125.98 @ Newegg)
Power Supply: Fractal Design Ion+ 760 W 80+ Platinum Certified Fully Modular ATX Power Supply
Case Fan: Noctua NF-F12 PWM chromax.black.swap 54.97 CFM 120 mm Fan ($22.90 @ Amazon)
Case Fan: Noctua NF-A14 PWM chromax.black.swap 82.52 CFM 140 mm Fan ($24.90 @ Amazon)
Total: $1817.37
Generated by PCPartPicker 2020-06-24 23:25 EDT-0400
