Budget (including currency): $2000 - $2700 $AUD
Country: Australia
Games, programs or workloads that it will be used for: Games.
PARTS:
MONITOR:
Is this a good setup? This is my first time building a PC. I haven't bought the parts yet, but I have bought the monitor. Overall, are the parts good? Will they all work together well?
any advice or suggestions are appreciated. Thanks
https://linustechtips.com/topic/1213672-need-help-with-pc-build/
i'd say if you haven't bought the parts yet you could wait for Big Navi and RTX 3xxx series GPUs cuz even if you won't need the extra power, you will see a drop in prices of Graphics cards which can make you go for a higher tier RTX 2080. Even for your CPU you could wait for Zen 3 as both Intel and AMD will drop their prices.
Otherwise, really solid build😉😉👍👍
very bad value cpu. ryzen 7 3700x bewats it by reasonable margin.
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
3 minutes ago, Sanguinereptile said:
but then i'd have to replace other stuff, i don't really know what I'd have to replace and with what. I don't know anything about amd.
I am not talking about replacing stuff. Just saying you could save a little bit more money if if you wait for the next-gen GPUs and CPUs.
