Budget (including currency): £800
Country: england
Games, programs or workloads that it will be used for: star citizen,streaming
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): so somebody i know is going to get a pc but they only have £800 for everything including monitor,keyboard,computer and windows 10(mouse is optional as i have a spare i could give him) he wants to play games at 1920 x 1080 30+fps
https://linustechtips.com/topic/1213334-help-buying-pc-or-prebuilt/
Definitely build. Prebuilt costs more for lower quality parts. I’ll update this with a recommended build.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
6 minutes ago, Spock_1701 said:
thanks
Two points:
- My RAM choice is suboptimal -- find a dual-channel kit if you can, since what I listed is a single-channel kit. Prices are high right now, though, so if you got the single stick I recommended, buying another matching stick down the line when it's cheaper is a good idea.
- A 2TB hard drive is always a good idea for extra storage. The 500GB SSD I recommended will hold a few games, and load them nice and fast, but not that many.
4 minutes ago, Spock_1701 said:
i know i am recreating your list with some tweaks for example 16Gb of ram and maybe a worse monitor you did however make a big mistake
the 1600 is 110 and the 3600 is 140 so with a £800 budget it works
Good spotting. I was sorting by lowest price since I didn't know how much you wanted left for peripherals, extra case fans, or whatever else. The R5 1600 isn't a bad CPU by any measure.
I would recommend the R3 3300X if you can find it -- it's not far off the R5 3600 in gaming performance whilst being cheaper. More cores doesn't always mean more better.
