Hello fellow reader. Can you help me,I have a problem. While i'm not doing absolutely anything on my pc my gpu usage is going from up to down and constantly has spikes (without doing a single thing) why it happens like this,and how can I resolve the problem!
Thanks in advance <3!
https://linustechtips.com/topic/1212966-help-gpu-usage-high/
Is this causing problems? If usage appears to be spiking but there's no symptoms other than that there's no reason to be concerned. If the spiking is causing stuttering or similar then there's cause for concern, and you can use task manager to find out what is causing the spikes. Hold F5 to refresh task manager faster if the spikes are too short to catch otherwise.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1212966-help-gpu-usage-high/#findComment-13747088
