Hi,
I don't know where this topic belongs, so I am trying it here. We have a stereo system which has a lightning plug, to plug in your iPhone to listen music off of it, but we only have a iPad, which doesn't fit because the port is in a hole, just as wide as a iPhone.
So here is my question: Is there something like a little Extension cable from female lightning to male lightning? So a cable to connect stereo and iPad?
https://linustechtips.com/topic/1212943-lightning-extension-cable/
from a quick google there seem to be a lot of options on amazon and aliexpress, so presumably these do what you want them to do.
for example: https://www.amazon.com/EMATETEK-Extender-Connector-Extension-Aluminum/dp/B07PW993GR?tag=reviewtap02-20
Thank you so much! When I googled, I only found these with USB C or some adapters form Lightning to USB C to Lightning.
