UPS Crazy Spikes on Gaming. is my PSU dying?
Solved by Guest,
3 hours ago, THEPRO | xTreme-CM.ORG said:
Yeah but the stange thing is this is a 800W PSU.. it cant be the wattage. maybe is broken or someting.
Yeah.. but it's a 10+ year old PSU. These things don't last forever. They might "put out power", but it's not like they were putting out the same kind of power they did TEN YEARS AGO!!!
Also, topologies change. The GS was an older double forward platform. You should never use a double forward with a 2080 Ti.
You have a Core i7 6700 and an RTX 2080 Ti and YOU'RE USING IT WITH A TEN YEAR OLD PSU!!!!
