Budget (including currency): 700-900€
Country: Germany
Games, programs or workloads that it will be used for: Streaming with OBS Studio
Other details:
I am currently building a Streaming PC for our church (Covid-19 Livestreams).
I want to stream in 1080p30 with OBS. Incoming are several network video streams (different Cameras and Image from the Projector)
My current plan is the following:
- Cheapest Brand PSU e.g. Corsair 400W)
- Cheap ATX case
- Ryzen 7 3700X or Ryzen 9 3900x
- 2x8GB DDR4-3200
- NVME 500GB (probably Crucial P1)
- Maybe a MSI X470 GAMING PLUS MAX
- GTX 1650 SUPER or a AMD RX 550 or 560.
So first of all what are your thoughts on the build regarding its purpose? I am relatively certain that it is sufficient from a performance side, I don't have that much experience with streaming though.
I basicially chose the MSI X470 GAMING PLUS since it was the cheapest option with a bunch of PCIe expansion slots. Currently I only need one Slot for a GPU, but I could imagine that in the future it is imaginable that I would want to use a 10G NIC and maybe a USB expansion. But from a performance standpoint, would you have any concern regarding a X470 or B550 or B450 board?
Since I prefer to use Software encoding the GPU is not that essential. I think I just for scaling and other filters OBS is not that GPU intensive. Am I correct on that?
So the only reason I consider the GTX1650 SUPER is that it is the cheapest card from Nvidia which has the new NVENC Engine, which probably won't be used, but I would like the option to. The AMD RX 550 or 560 also have Hardware Encoding units, but I didn't found much information on how good they are.
I would be grateful for your feedback and suggestions.
Thanks
lal12
https://linustechtips.com/topic/1212378-streaming-pc-for-obs/
22 minutes ago, gloop said:
Drop the cpu down to a 3600, get a b505
mobo, but the cheapest 1660 for nvenc, good quality 450w psu.
Thanks I think I might choose a cheaper mainboard, if I find something with enough slots for the same/lower price. The MSI X470 GAMING PLUS MAX seems to be price reduced for currently 120€.
Yeah 450-500W PSU is probably better.
https://linustechtips.com/topic/1212378-streaming-pc-for-obs/#findComment-13742545
26 minutes ago, YT_DomDaBomb20 said:
Looks good, still thinking about going ATX for more expandability, but this is obviously not a performance issue.
Though are you sure about the Ryzen 5 1600? For NVENC probably fine, but also for Software Encoding?
https://linustechtips.com/topic/1212378-streaming-pc-for-obs/#findComment-13742723
It’s basically a 2600, it’s a 1600af, so it uses zen + architecture
https://linustechtips.com/topic/1212378-streaming-pc-for-obs/#findComment-13742772
