Right so I've decided to finally get around to upgrading my rig, but I have run into some problems in what to get.
Basically all I need is the CPU and the GPU. I was originally going to get the 3300x and pair it with the 1660 Super, but now I have just added roughly another £150-200 to the build budget and thought that I maybe want to upgrade my GPU even further.
I thought that a 5600xt would pair nicely and give me some money left over or i could go all out and get the 5700 or 5700xt.
Pretty much I just want to know what to get out of those GPUs,
Or maybe i could get a 2060 because I know that the AMD cards have driver issues right now
Also are AMD cards really that unreliable or have they recently gotten better?
https://linustechtips.com/topic/1212335-upgrade-help/
So now that you added the extra 200 pounds
What's your budget exactly ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1212335-upgrade-help/#findComment-13742098
5 minutes ago, PlumpPlatypus said:
Something like the Gigabyte gaming OC 5700XT for £380 would be very nice, and should be pretty future proof
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1212335-upgrade-help/#findComment-13742104
Well all i need is a GPU because i think im going to stick with the 3300x. So like i said i was originally going to get the 1660 Super which is £220 but I got some extra money to play with and thought of upgrading just my GPU, is it worth going all out and getting a 5700xt or saving some @TofuHaroto
https://linustechtips.com/topic/1212335-upgrade-help/#findComment-13742105
1 minute ago, PlumpPlatypus said:
Do you know is the driver issues have been fixed?
They have for the most part
If you want
Get a 1660 super and wait for ampere and big Navi
Or go all out and get a 5700xt
Build Log:
https://linustechtips.com/topic/1212335-upgrade-help/#findComment-13742115
If you want
Nice thanks for the help and do you think the 3300x would be able to handle the 5700xt? @TofuHaroto
https://linustechtips.com/topic/1212335-upgrade-help/#findComment-13742136
It will
A 3300x is a very capable chip
Build Log:
https://linustechtips.com/topic/1212335-upgrade-help/#findComment-13742139
3300x is enough for now. Really good CPU. But keep in mind that's a 4/8 CPU. New consoles that will arrives at the end of this year will have 8/16 CPU. Something like Ryzen 7 3800. So don't expect that this CPU will handle for too much time.
In fact, some games are already showing what happens when you have less logical cores than the game is optimized for. Link below. Look for Assassins Creed Odyssey and Battlefield 5. They're paired even 3300x having a better architetury than Ryzen 1600AF.
Now give it a close eye on RDR2. 10% more performance than 3300x. It's a very modern game.
I'm not saying that you should buy a 1600AF and forget about 3300x. It's not that. It's just to keep in mind that 3300x is fast, but in the end it's a quad core that have 8 logical cores, half of the new consoles.
https://adrenaline.com.br/analises/v/63872/analise-amd-ryzen-3-3300x-cpu-atropela-o-core-i3-e-ate-rivaliza-com-i5
https://linustechtips.com/topic/1212335-upgrade-help/#findComment-13742416
