Hey guys..i am linggeis from Malaysia. I am currently having some problems in my system. I am using Ryzen 3 3300x processor with Asrock A320M HDV R4.0 motherboard and 550 W EVGA 80+ gold with Gigabyte Gtx 1660 oc 6gb.
However,when i on the system,the fan spins everything runs. But when i connect the hdmi from graphics to the monitor, there is no signal. Does this mean i need to update the bios? i have looked at the manufacturers website if the processor is supported by my motherboard and it is listed...Currently dont know what do :( Hope to get some input from you all.
https://linustechtips.com/topic/1212325-need-help-for-my-system/
4 minutes ago, Linggeis30 said:
so does that mean i will have to bios update?
https://www.asrock.com/MB/AMD/A320M-HDV R4.0/index.asp#CPU
Says it's supported on their wesite
The purpose of life is to contribute in some way to making things better - RFK
Most likely
A320 will need a bios update to support the AGESA for zen 2
If possible just put your old cpu back and update the bios
If you don't have one just take it to a computer store and ask them if they can update it for you
Phone: Pixel 3a (Purple-ish).
Build Log:
6 minutes ago, TofuHaroto said:
Most likely
Yeah i agree..i have searched many website.. this is the only solution i get. Thank you for the help :)
No problem
Build Log:
9 minutes ago, Linggeis30 said:
 G.SKILL AEGIS DDR4 3200MHZ 8GB..this is the memory i am using
https://www.gskill.com/qvl/165/185/1567584456/F4-3200C16S-8GIS-Qvl
A320 support not on the QVL list for this memory
QVL list means nothing other than it isnt 100% to work.
bios update is my guess over memory
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
^ this
Beat me to it lol
Build Log:
