I just built a new rig and I am having major problems overlocking my RAM with Asus' DOCP profile.
Specs are:
Ryzen 5 3600
B450-F ROG STRIX
Corsair RGB Pro 16GB 3200Mhz
MSI 2070Super Ventus
Corsair 650M
So after a couple times trying to set the DOCP profile and not getting the 3200MHz I put everything on default at which point my computer crashed and I had to restore Windows in order for it to work. It was frastruating to say the least and I am wondering if it is the RAM causeing this problems and if I should return it. The RAM is currently running at 2133MHz and I don't want to touch the DOCP settings again in case it crashes.
Any advice on what to do?
Thank you in advance.
https://linustechtips.com/topic/1212288-problems-with-asus-docp/
A couple of things
Put the ram in slot 2 or 4 or whichever slot that allows you to use dual channel ( look at the manual )
Now
Update the bios
Set the soc to 1.1
Dram to 1.35
Set it to 3200
If it boots
Use memtest86 and OCCT to verify that it's stable
If you have any over clock remove it just to avoid FCLK limitations  ( not including XFR)
If it boots and you verified it's stable
Set your over clock profile back again and check if it's stable
Good luck ;)
Phone: Pixel 3a (Purple-ish).
Build Log:
7 minutes ago, TofuHaroto said:
A couple of things
Set the ram in slot 2 or 4 or whichever slot that allows you to use dual channel ( look at the manual )
Now
Update the bios
Set the soc to 1.1
Dram to 1.35
Set it to 3200
If it boots
Good luck ;)
Hey I just noticed that my Ryzen 3600 is running at around 4.2GHz but I haven't set anything up could you think of how?
4.2 is normal for a 3600
Either way as I said if you have XFR don't worry about it
Just do the things I listed above
Build Log:
I did the tests and CPUZ says that it is running at 3200MHz.. Thank you so much. Will update you when I do the tests
No problem
Good luck ;)
Build Log:
