Budget (including currency): 1000€
Country: Austria
Games, programs or workloads that it will be used for: GTAV, Fortnite, Android Studio, OpenAI
PCPartPicker Part List: https://de.pcpartpicker.com/list/7DGYGc
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor  (€166.00 @ Mindfactory)
Motherboard: Asus TUF GAMING B550M-PLUS Micro ATX AM4 Motherboard  (€155.99 @ Amazon Deutschland)
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€73.89 @ Alternate)
Storage: Western Digital Blue 500 GB M.2-2280 Solid State Drive  (€66.00 @ Amazon Deutschland)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  (€37.99 @ Amazon Deutschland)
Video Card: Gigabyte GeForce GTX 1660 SUPER 6 GB OC Video Card  (€244.71 @ Mindfactory)
Case: Fractal Design Meshify C ATX Mid Tower Case  (€101.89 @ Alternate)
Power Supply: Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  (€83.89 @ Alternate)
Total: €930.36
Generated by PCPartPicker 2020-06-21 04:07 CEST+0200
https://linustechtips.com/topic/1212217-first-pc-build/
Motherboard: MSI B450-A PRO MAX ATX AM4 Motherboard  (€100.89 @ Alternate)
Memory: ADATA XPG GAMMIX D10 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (€64.06 @ Amazon Deutschland)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive  (€59.99 @ Amazon Deutschland)
Video Card: Sapphire Radeon RX 5700 XT 8 GB PULSE Video Card  (€393.90 @ Mindfactory)
Case: Corsair SPEC-DELTA RGB ATX Mid Tower Case  (€69.90 @ Amazon Deutschland)
Power Supply: BitFenix Formula Gold 550 W 80+ Gold Certified ATX Power Supply  (€69.90 @ Amazon Deutschland)
Total: €962.63
Generated by PCPartPicker 2020-06-21 04:23 CEST+0200
https://linustechtips.com/topic/1212217-first-pc-build/#findComment-13741219
Something like this would be a lot better; ram speed brought up to 3600, if you really want to have "future proofing" I would go with an x570 board instead, or with a b450 if you want to save some money (something like a msi b450 tomahawk max is good), again if you want to save some money you could go with an rtx 2060 instead but this card is slightly faster (it draws more power and produces more heat, something to be aware of), power supply was upgraded and cheaper, however it is not modular. Not really sure what you want with the case, but I personally would not recommend spending over 80 euro on a case, there is plenty of good cases in this price range.
https://linustechtips.com/topic/1212217-first-pc-build/#findComment-13741244
