my parents using my laptop, clicked on some link and downloaded the pro zipper virus.
my USB flash drive has been write protected and I can't use it.
I have tried the "regedit" , "CMD" , and other software formatting methods but nothing seam to work.
 Dose anyone have a solution for this issue?
https://linustechtips.com/topic/1211927-usb-drive-is-write-protected-help-needed/
Are you trying to recover files or just make the drive usable again?
 CHRISTIAN MEMBER
1 minute ago, sakthiprakash said:
Make the drive usable
Easy enough 👍
17 minutes ago, Grumpy Old Man said:
1. Create new partition table (mbr or gpt)
2. format the usb-drive normally
DA DAA
I would follow this ^^^ see what happens and let us know if it works.
 CHRISTIAN MEMBER
