Case Fans Quality
Cooler Master SickleFlow fans are rubbish. They're sleeve bearing fans which will vibrate more when mounted horizontally because a sleeve bearing is exactly that a metal sleeve roating inside of another metal sleeve with only a thin film of oil between the two. When you mount a sleeve bearing horizontally there is nothing to keep the oil in place and it kind of just slings out and then the bearing seizes up eventually due to lack of lubrication.
A rifle bearing is similar to a sleeve bearing except there is a key difference the inner sleeve has a rifling in it (a twisty groove pattern) which is theoretically supposed to help "pump" the lubricant from some sort of reservoir up the bearing around and keep it from just being slung out of the bearing.
FDB bearings or (Fluid Dynamic Bearings) are usually a sort of rifle bearing with some minor modifications.
Ball bearings are traditional bearings like you see on cars and trucks etc. These are bearings that use balls to separate the inner and outer bearing races and by using balls to do so it reduces the rotational friction between the surfaces. These tend to be noisier but last a lot longer and they don't care how they're mounted.
Maglev bearings use magnetic force to suspend the rotational parts without physical contact. These have been around for a long time but corsair has made them more popular as of recent.
If you want a fan to mount horizontally stick with anything that is NOT a sleeve bearing fan.
Sleeve bearing fans tend to need relubrication every once in a while you can usually do this by carefully peeling up the sticker on the back and removing the plug and placing a drop of sewing machine or like light weight oil in and then place the plug back in and smooth down the sticker. The plug and sticker keep dust and garbage from getting into the bearing.
Hope this helps.
