Hi, so I was downloading some large files on my pc. While doing this I was downloading the files to my os drive by mistake. This made the os drive full and after a reboot the screen is stuck as pictured and nothing is stressed. At this point I'm prepared to just do a fresh os install and would be preferable. I hope someone can help.
Thanks ❤️
https://linustechtips.com/topic/1210912-help/
10 minutes ago, si1enze said:
If you have another computer, you could download/burn a Ubuntu bootable ISO to a DVD and boot up with that.  Then use it's file manager to free up space on the drive..
I tried that earlier with pop and when I tried booting from the flash drive(I dont have a DVD burner) the iso wasnt read.
https://linustechtips.com/topic/1210912-help/#findComment-13730930
