Hello everyone , my pc has been crashing sometimes out of nowhere even when im watching videos it happens too , ill post the dump file , i havent istalled anything recently , and i noticed that sometimes when it crashes,  my gpu driver seems to be gone because everything is pixelated as if there was no driver installed
heres my dump file :
************* Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       srv*
Symbol search path is: srv*
Executable search path is:
Unable to load image Unknown_Module_ff040200`ff0b0907, Win32 error 0n2
*** WARNING: Unable to verify timestamp for Unknown_Module_ff040200`ff0b0907
Debugger can not determine kernel base address
Windows 10 Kernel Version 18362 MP (12 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Machine Name:
Kernel base = 0xfffff807`16a00000 PsLoadedModuleList = 0xfffff807`16e48190
Debug session time: Wed Jun 17 12:48:05.028 2020 (UTC + 2:00)
System Uptime: 0 days 4:36:39.703
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
..Missing image name, possible paged-out or corrupt data.
For analysis of this file, run !analyze -v
fffff807`16bc23a0 ??              ???
2: kd> !analyze -v
*                        Bugcheck Analysis                                    *
INTERRUPT_EXCEPTION_NOT_HANDLED (3d)
Arguments:
Arg1: ffff9f0b6343f2a8
Arg2: ffffd9005cb11930
Arg3: 0000000000000000
Arg4: 0000000000000000
Debugging Details:
***** Debugger could not find nt in module list, module list might be corrupt, error 0x80070057.
KEY_VALUES_STRING: 1
    Key  : Analysis.CPU.Sec
    Value: 0
    Key  : Analysis.DebugAnalysisProvider.CPP
    Value: Create: 8007007e on DESKTOP-8EVNAUB
    Key  : Analysis.DebugData
    Value: CreateObject
    Key  : Analysis.DebugModel
    Value: CreateObject
    Key  : Analysis.Elapsed.Sec
    Value: 0
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 42
    Key  : Analysis.System
    Value: CreateObject
    Key  : WER.CorruptModuleList
    Value: 1
ADDITIONAL_XML: 1
BUGCHECK_CODE:  3d
BUGCHECK_P1: ffff9f0b6343f2a8
BUGCHECK_P2: ffffd9005cb11930
BUGCHECK_P3: 0
BUGCHECK_P4: 0
CONTEXT:  ffff9f0b6343f2a8 -- (.cxr 0xffff9f0b6343f2a8)
Unable to read context, Win32 error 0n30
CUSTOMER_CRASH_COUNT:  1
STACK_TEXT:
ffffd900`5cb11138 fffff807`16caa745 : 00000000`0000003d ffff9f0b`6343f2a8 ffffd900`5cb11930 00000000`00000000 : 0xfffff807`16bc23a0
ffffd900`5cb11140 00000000`0000003d : ffff9f0b`6343f2a8 ffffd900`5cb11930 00000000`00000000 00000000`00000000 : 0xfffff807`16caa745
ffffd900`5cb11148 ffff9f0b`6343f2a8 : ffffd900`5cb11930 00000000`00000000 00000000`00000000 fffff807`16a594b3 : <Unloaded_Unknown_Module_00000000`00000000>+0x3d
ffffd900`5cb11150 ffffd900`5cb11930 : 00000000`00000000 00000000`00000000 fffff807`16a594b3 00000000`00000000 : 0xffff9f0b`6343f2a8
ffffd900`5cb11158 00000000`00000000 : 00000000`00000000 fffff807`16a594b3 00000000`00000000 fffff807`16bcb18f : 0xffffd900`5cb11930
SYMBOL_NAME:  ANALYSIS_INCONCLUSIVE
MODULE_NAME: Unknown_Module
IMAGE_NAME:  Unknown_Image
STACK_COMMAND:  .thread ; .cxr ; kb
FAILURE_BUCKET_ID:  CORRUPT_MODULELIST_0x3D
OSPLATFORM_TYPE:  x64
OSNAME:  Windows 10
FAILURE_ID_HASH:  {6833192f-3406-a9b4-0f13-22063211171a}
Followup:     MachineOwner
https://linustechtips.com/topic/1210568-need-help-with-bsod/
Looks like the GPU is taking a dumb. I'm sorry :/
Try running the PC on integrated GPU, see if it happens again. Make sure to connect Display cable to MoBo port. Look at what windows crash log says. It usually says exactly which components exampled a non-recoverable error.
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13727901
oh god , it just started happening out of nowhere it happens more when im browsing or alt tab from a game , but while playing it rarely occurs, ill try to do that and then ill post the results
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13727907
2 minutes ago, Miguelc said:
Specs ?
Clear the cmos
Update windows
Get the latest bios
Try with one stick at a time
Run memtest86 and OCCT
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13727917
Just now, TofuHaroto said:
Specs ?
Clear the cmos
Update windows
Get the latest bios
Thank you for replying
my specs are following
CPU I7 8700 K
GPU: GTX 1080 MSI ARMOR 8GB  OC
RAM : 2x ripjaws 2400 mhz
HDD : 1 TB Games on it
SSD : 120 GB OS on it
PSU : Coolermaster masterwatt lite 700 w
Bios is the latest version , ill try to run memtest86 and see if its ram related
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13727930
Try ddu while your at it
Build Log:
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13727932
1 minute ago, Miguelc said:
yeah i use it everytime a new driver comes out ill also try to rollback a couple of versions because it has been hapening since a couple of versions before the 446.14
Then try memtest86 and OCCT
Good luck ;)
Build Log:
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13727954
Hello again :)
 i ran memtest with 0 errors detected , also ran occt on my gpu for like 5 mins without any errors temp went up to 71 c but no crashes , could it be gsync causing it? im using a 144 hz display , i read somewhere that it can cause some crashes when using high refresh rate display with gsync , but sadly i have to use gsync because of tearing no matter what i do i get it without gsync :S
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13728706
Hello again :)
EDIT: ok i just ran power stress test for like 1 min and came back with 137849 errors wtf , i shut it down because my cpu was on 80 c since i have a 4.7 ghz oc on it , what could these errors mean ?
screenshots of occt :
https://imgur.com/a/6ou0QNa
EDIT AGAIN : I lowered my cpu oc from 4.7 1.200 v to 4.5  at 1.190 and ran the same test with no errors :S
https://linustechtips.com/topic/1210568-need-help-with-bsod/#findComment-13728732
