Try using the cable with the other monitor and see if it works. Also try using that monitor with the cable from the first monitor. That way you know if either of those is faulty.
I am far from an expert in this so please correct me if I’m wrong.
Quote or tag me so I can see your response
PSU Tier List
Motherboard Tier List
Graphics Card Cooling Tier List
CPU Cooler Tier List
SSD Tier List
PARROT GANG
Mentioned in 7/10/20 WAN Show
Mentioned in 7/15/20 Techlinked
Mentioned in 7/17/20 Techlinked
Mentioned in 7/31/20 WAN Show
Mentioned in 7/31/20 Techlinked
Mentioned in 8/3/20 Techlinked
Mentioned twice in 8/5/20 Techlinked
Mentioned twice in 8/7/20 Techlinked
Mentioned in 8/12/20 Techlinked
Mentioned in 8/19/20 Techlinked
https://linustechtips.com/topic/1210338-using-2-displays/#findComment-13726011
I think it might be the adapter. because it DID work once but then it stopped working completely. thank you! :) (and I know the cable im using for it is good!)
https://linustechtips.com/topic/1210338-using-2-displays/#findComment-13726025
