I have a 1050 TI, not a fake off wish, has been working for a year or two fine, but now i have noticed Fortnite is crashing, and it happens in CSGO and Roblox too. Fortnite says there are known problems with my drivers, so i tried to update them. I try through GeForce experience, doesn't work. I try a clean install through GeForce experience, doesn't work. I do the same thing with the direct download from the Nvidia website instead of GeForce experience clean and non-clean, doesn't work. I've deleted all nvidia things i can find, doesn't work. Got rid of my overclock and nothing.
System Specs: CPU: I5-6600k, RAM 32GB DDR4-2666 GPU: 1050 TI 4GB, Power: 450W Corsair, Drives: 250GB SATA 3 Boot SSD, 1.5TB 7200RPM SATA 3 SSD Motherboard: Asrock H110M
https://linustechtips.com/topic/1210124-help/
Use ddu ( display driver uninstaller )
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1210124-help/#findComment-13724203
Finally the perfect scenario for your DDU recommendation. 😁
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1210124-help/#findComment-13724220
Never too late
But still it is a suggestion that could work in alot of situations
Build Log:
https://linustechtips.com/topic/1210124-help/#findComment-13724228
@TofuHaroto, @HairlessMonkeyBoy, or quote us if you want us to see your response.
Did you run DDU in safe mode?
What OS are you using? If Windows 10, was it an upgrade from a previous Windows version or a fresh install?
A fresh Windows 10 install might be a good idea.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1210124-help/#findComment-13725032
1 minute ago, AptLane said:
No, didn't run in safe mode. Bad thing? @HairlessMonkeyBoy
Yes. Follow the recommended instructions and run it in safe mode.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1210124-help/#findComment-13725274
@HairlessMonkeyBoy I didn't the first time, my dad found something in a log file and decided to update windows. Apparently that was a bad idea because now it won't boot. Might wipe like you suggested. Is there any way I can keep the info on my second drive? I have over a TB of important shit I really don't wanna lose.
https://linustechtips.com/topic/1210124-help/#findComment-13725288
The instruction on the DDU page are pretty clear. Following them would have been a good idea.
Yes, just unplug it during the install.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1210124-help/#findComment-13725318
