Premiere Pro Build
Go to solution Solved by gloop,
5 minutes ago, FizzFantom said:
My local computer store has a ASUS ROG STRIX B550-E on stock. Good?
Yes, it’s in the same tier as the Tomahawk.
Enjoy your build!
Budget (including currency): € 2000
hi guys,
I would like to build myself a PC that is capable of running video editing software (in my case Premiere Pro) and Photo editing software (also the Adobe stuff)  smoothly and is also capable of rendering everything in a decent amount of time.
I currently work on a MacBook Pro 15" with an RX 5700 XT as eGPU and I am quite happy with the preformace but I think there is more out there.
I would like to build a PC that can last a couple of years and will not be out of date in a few months.
Could anyone help me choose components that fit the need and also are in my budget?
The Radeon would stay, so graphic card would not be in the budget.
regards and happy monday
https://linustechtips.com/topic/1209714-premiere-pro-build/
how heavy is your videos?
what cpu do you have in your mac right now?
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13720854
Nothing extremy exciting. I do image films for museums and hotels. Nothing over 4k, in general nothing over 80 MBit/s with a few filters and blurs. I think that my workload is not that high. But i would like to get better and accept bigger jobs.
2,7 GHz Quad-Core Intel Core i7 with 16 GB of RAM
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13720919
PCPartPicker Part List
CPU: AMD Ryzen 9 3950X 3.5 GHz 16-Core Processor  ($699.99 @ Amazon)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler  ($89.95 @ Amazon)
Motherboard: MSI MPG X570 GAMING PLUS ATX AM4 Motherboard  ($169.99 @ Best Buy)
Memory: G.Skill Trident Z Neo 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory  ($178.99 @ Newegg)
Storage: Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive  ($179.99 @ Amazon)
Storage: Hitachi Deskstar 3 TB 3.5" 7200RPM Internal Hard Drive  ($99.63 @ Amazon)
Case: NZXT H510 ATX Mid Tower Case  ($69.99 @ Best Buy)
Power Supply: Corsair CXM 650 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($94.99 @ Best Buy)
Total: $1583.52
Generated by PCPartPicker 2020-06-15 14:03 EDT-0400
This will last you very long time, but not really necessary, you can do it much less.
But since you have 2000 to waste.
With no effects a 6 cored cpu will just be fine for 4k editing.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13720982
Total: $1583.52
You are a demigod. Thanks a lot.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13720996
Plus you can hackintosh it and get your macbook to shame.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721005
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core Processor  ($416.88 @ Amazon)
Motherboard: Gigabyte X570 AORUS PRO WIFI ATX AM4 Motherboard  ($269.00 @ B&H)
Total: $1499.05
Generated by PCPartPicker 2020-06-15 14:17 EDT-0400
You can also do this, 1 step lower cpu, but better motherboard and another hdd for the same money.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721034
Total: $1499.05
I would not really use the local storage. All date is on an NAS. Or would you recommend working local?
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721040
I see nas as a long term storage, not for working, unless you have a 10gbps network.
But since you have nas, i think 1 hdd should be enough.
the rest of your budget can go to better monitor and gears.
another thing to mind, do you need it now, or can you have it later like december, because AMD will release a new processors lineup by then.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721079
Total: $1583.52
That board will not handle a 16 core cpu.
@FizzFantom Avoid the MSI board as it is garbage.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721194
22 minutes ago, FizzFantom said:
I see.
Will this new lineup make a great difference in price in regards to the 3950X? Because a dip of 15-20% does not really make it worth the wile.
honestly in terms of performance you will only loose 20% rendering speed, the 12 cores is really enough even for 4k and beyond, as i said even a 6 core is fine, the difference is just the rendering.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721229
20 minutes ago, FizzFantom said:
That board is fine, as any Asus X570 board. Only good MSI X570 is the Tomahawk which is hard to get at the minute, and the Unify and Ace. The other MSI X570 should be avoided. Also the B550 boards are supposedly due out tomorrow.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721524
Thanks, I will keep that in mind.
Should i stay with the Rx 5700 XT or should o get another card and sell that one?
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721543
So AORUS or ASUS are good X570 boards?
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13721651
The link below suggests that Nvidia is preferable to AMD if you are using gpu acceleration.
https://www.pugetsystems.com/recommended/Recommended-Systems-for-Adobe-Premiere-Pro-143/Hardware-Recommendations
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13722036
Much better motherboard choice with the Aorus Ultra.  The MSI x570 boards are actual trash or merely overpriced depending on the model.
ALL AMD ALL THE TIME: AMD Ryzen 9 3900x | 32GB DDR4-3600 CL16 G.Skill RAM | Gigabyte x570 Aorus Master Motherboard | Powercolor RX 5700 XT Red Devil | 1TB Samsung 970 Evo M.2 NVME Boot Drive | 1TB Samsung 860 QVO Game Drive | Lian Li PC-011 Dynamic Black Case | Corsair RM750 Power Supply | Corsair H150i Pro 360mm Liquid Cooler | 7x Noctua NF-P12 120mm PWM Fans | Acer XV272U 27" 1440p 144hz IPS & VG270U 27" 1440p 75hz IPS | Logitech G610 Keyboard, Z625 2.1 Speakers, C920 Webcam | Glorious Gaming Model D Mouse | Focusrite Scarlett Solo USB Audio Interface | Audio Technica AT2020 Condenser Microphone | Beyerdynamics DT770 Pro Headset | Kingston Cloud Revolver S Headset |Microsoft Windows 10 Professional
Main hoe turned side piece NAS/HTPC/f@h slampig: Intel i7 4790k under Corsair H105 | ASRock Z97 Extreme 4 | 32GB DDR3-1866 Crucial Ballastix | EVGA GTX 1070 SC | 250GB Samsung 850 Evo SATA drive | 2TB Western Digital Green HDD | NZXT H440 | Microsoft Windows 10 Pro | 55" Samsung 4K QLED
Support Stack:  Cyberpower 1300VA UPS backup | Google Nest Wifi + Gigabit Fiber Internet | Raspberry Pi 3 pihole | 2x Unmanaged Netgear GS308 Switches
Pre-ordered and on it's way:  Ducky Mecha Mini v2 w/ Cherry Browns.  On the road to De-Logiteching my rig.  Keyboard/Mouse down.  Webcam/Speakers to go.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13723320
I'll also say, personally I really don't like the NZXT H510, it's got bad thermals compared to some of the mesh front cases like BeQuiet! Pure Base 500Dx that also comes with 3x quality 140mm fans installed.  But other than that I think the build looks very solid.
I'd personally look at like the Meshify C, Cooler Master TD500 or H500 mesh as well.
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13723330
13 minutes ago, FizzFantom said:
What exactly is the difference?
Not that much really. For the average user a B550 will be fine. The prices might not be that much cheaper though as new boards always tend to be more expensive than the previous ones until they settle down.
https://www.gamersnexus.net/guides/3582-amd-chipset-differences-b550-vs-x570-b450-x470-zen-3
https://linustechtips.com/topic/1209714-premiere-pro-build/#findComment-13724971
