Hey All,
I recently decided to give my quite some year old i5-2500k an upgrade and after some research I did a 'budget' rebuild using only the Old Case and the PSU (that I have to Upgrade ASAP I think). Im not the 'heavy' gamer (Rocket League, CS GO, Crysis ...) but use my PC mostly for Programming (thats why I also chose Nvidia, because they got cuda support for Tensorflow - that makes it so much faster).
I decided for the following:
CPU: Ryzen 5 3600
GPU: MSI GTX 1660 Super
Motherboard: MSI B450 Gaming Plus
RAM: 16GB G.Skill Aegis CL16-18-18-38
I also modded the old case (Zalman Z9 Plus) a little and used a HR-02 Macho as aircooler.I might change the powersupply pretty soon as it is a sort of no-name (Superflower 550W)...
Im pretty happy but got a little worried that i chose the wrong GPU, as the 2060 is not that much more expensive but more powerful i guess.
Anyways the system runs fine, i tried tweaking the memory a little as its rather on the 'slow' side and quickly ran into small stability issues. Sometimes when i start up a game the system crashes without bluescreen or anything, the screen goes black, fans still spinning but nothing responds... I am currently reverting the overclocks and try different stress tests.
Is there anything i could do to figure out what the problem could be?
Does anyone using similar components have some tips on performance and small overclocks that are useful but stable? :)
Are there any other components that could work better?
Thanks for the tips :)
Greetings
https://linustechtips.com/topic/1208859-pc-upgrade-some-small-problems/
Update the bios
Set the soc to 1.1 and try that ?
Phone: Pixel 3a (Purple-ish).
Build Log:
@Kewpcool have you tried upping the voltage? What speed is the ram at stock? I have a Ryzen 5 1600  I got it to 3.85 ghz @ 1.385V with the stock cooler. And my ram is Corsair vengeance lpx stock 3000 mhz and oc’d to 3200 with 1.36v. I suggest watch ltt’s video on Ryzen overclocking.
@Lemon797
@TofuHaroto
Thank you guys for the fast answer, the RAM is normaly 3000 MHz stock. I enabled XMP and did like in the LTT Video where they explain RAM overclocking for Ryzen. Anyways I overclocked the CPU via Ryzen Master and just recently i Installed Docker for a project I need and if I am remembering correctly the crashes started after that. It might have to do with the Hyper-V that has to be turned on in order to run Docker on Windows... Because if this is turned on I cant open Ryzen Master anymore and (I didnt check this correctly) the CPU clock was stuck at 4.1Ghz all the time.
9 minutes ago, Kewpcool said:
Ddu
Update the bios
Check temps
Up the soc to 1.1 and dram to 1.35
Try with one stick at a time
What PSU do you currently have ?
Build Log:
4 hours ago, Kewpcool said:
@Lemon797
@TofuHaroto
I don't think you should have XMP on and what are you using to cool your CPU?
