Destiny 2 problems
Go to solution Solved by Fatih19,
I suspect the i3 to be the source of the stutter. Some games today use more than 4 threads.
So I recently got a 1660 super paired with 16gb i3 8100 plans to upgrade cpu in the future. For some reason when i get over 72 fps in destiny 2 its just major stuttering to the point that its unplayable. I am aware that an i3 8100 is not great for the gpu paired with it but only destiny 2 i could really use some help.
https://linustechtips.com/topic/1208482-destiny-2-problems/
that doesn't do anything its not really a fps issue but its so unplayable. Its just odd idk if the game is just poorly optimized or what. My friend has a 1660ti and i5 9400f and punches out around 144 fps. I know that the 1660 super and ti are about the same so it really bothers me.
https://linustechtips.com/topic/1208482-destiny-2-problems/#findComment-13717137
  • 3 months later...
I know it doesn't solve the problem per se, but worst case can't you just set the fps to go no higher than 70?
It's still very playable at that fps, and at least you won't have such a frustrating experience?
https://linustechtips.com/topic/1208482-destiny-2-problems/#findComment-14045530
Your GPU is 100% enough. That i know.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1208482-destiny-2-problems/#findComment-14045770
Main Rig :
Ryzen 7 2700X | Powercolor Red Devil RX 580 8 GB | Gigabyte AB350M Gaming 3 | 16 GB TeamGroup Elite 2400MHz | Samsung 750 EVO 240 GB | HGST 7200 RPM 1 TB | Seasonic M12II EVO | CoolerMaster Q300L | Dell U2518D | Dell P2217H |
Laptop :
Thinkpad X230 | i5 3320M | 8 GB DDR3 | V-Gen 128 GB SSD |
https://linustechtips.com/topic/1208482-destiny-2-problems/#findComment-14046848
