I have a remote control car which uses a battery pack of two 3.7v capacitors and a 4pin plug with 4 wires coming from the plug when I charge the batteries using a usb charger it only charges one battery, I tested it using my mustimeter that's how I know.
Is this normal or is something broken?
CPU: i9-9900k
Motherboard: MSI Carbon Pro AC
Memory: GSkill Trident Z Royal Silver 32gb
Storage: SanDisk - Ultra II 480GB 2.5" Solid State Drive
Storage: Western Digital - Blue 4TB 3.5" 5400RPM Hard Drive
Video Card: ASUS Strix GTX 1050ti 4GB
Case: Corsair - Vengeance C70 (Black) ATX Mid Tower Case
https://linustechtips.com/topic/1208019-only-charging-one-battery/
Are you sure they are capacitors and not batteries.  Those two things look a lot alike but are totally different in the way they work.  Or, does it have two capacitors AND two batteries.  Not to sure what you have from the way that you describe your setup.
There are 2 capacitors from what it says on the side of them.
CPU: i9-9900k
