1 minute ago, jonfunko said:
Is their a similar site for TV's like their is for PC components I'm trying to find a 4k hdr hdmi 2.1 tv but  struggling to find out what options their are?
Your best bet would be to type it into Google and see what comes up. Google has a Shopping Tab.
https://www.google.com/search?biw=1344&bih=694&tbm=shop&sxsrf=ALeKk03YM77arrLHpfzTcghVqij36KRGmQ%3A1591904078085&ei=TofiXsvYBLKxggfWu724Dw&q=4k+hdr+hdmi+2.1+tv+&oq=4k+hdr+hdmi+2.1+tv+&gs_l=psy-ab-sh.3..0i8i30k1.7966.7966.0.8143.1.1.0.0.0.0.107.107.0j1.1.0....0...1c.2.64.psy-ab-sh..0.1.106....0.AseQJwTxeHc
https://linustechtips.com/topic/1207956-pc-part-picker-for-tvs/#findComment-13706547
Nothing exists as far as I know that has search parameters you can modify to narrow down your search for TVs, like PCPartPicker but my suggestion is look for TVs in your price range and look them up on RTings, they'll have all the info on them and extremely thorough reviews. If they're not on RTings they're either quite new so they haven't had time to review them yet, or probably not worth your time at least in my experience using this method.
Also if you're planning to buy a 4K TV soon Vizio will likely be unveiling their new 2020 models as soon as June 30th at least from what information is available. Could be Q4 they release though as I'm sure production has been interrupted due to coronavirus.
- Personal Rig -
AMD 7950X3D / 64GB G.SKILL DDR5-6000 EXPO / ASUS RTX 4090 TUF OC
ASUS ProArt X670E / Noctua NH-D15 Corsair 4000D Airflow / Corsair RM1000x / 4 x 2TB Crucial P5 Plus
- 🪦 HW Graveyard 🪦-
MSI GTX 780 Lightning 3GB 🪦🫡 Dec 2013 - Dec 2018
Seasonic Platinum 1000W 🪦🫡 Dec 2013 - Dec 2018
PNY GTX 470 1280MB 🪦🫡 June 2010 - August 2017
Intel Q9550 / Q9450 Systems 🪦🫡 Q1-2008 - Q3-2016
- Desktop Audio Equipment -
ADAM Audio F7's | Topping D30 Pro | Topping A30 Pro | HD598 & HD6XX w/ Sheepskin Pads
https://linustechtips.com/topic/1207956-pc-part-picker-for-tvs/#findComment-13706908
