Budget (including currency): £1000
Country: UK
Games, programs or workloads that it will be used for: General use and mid range gaming Cyberpunk 2077 will be highest end for now
Current Spec
Ryzen 2700
MSI Carbon Pro X470
16 Gb Corsair Vengance 3200
MSI RTX2070 Twin Frozer 7
970 512Mb MVME
1Tb generic HDD
Looking to Get a new Case (existing case has poor airflow and fans are failing) motherboard, CPU, PSU possibly memory and (not in this budget) GPU but am getting lost in the multiplicity of options
currently am water cooling CPU with 240mm AIO with no overclocking
Whilst I do have some wiggle room on budget I would like to get close to that if I can
https://linustechtips.com/topic/1207886-need-help-refining-upgrade-path/
Not looking at the GPU in this budget, that will come in about 6 months, also looking to go next gen on motherboard (I have an X470 board atm) so it is there for future CPU upgrade.
Like the case and PSU tho, what are your thoughts on XT chips
Country: UK
Current Spec
Ryzen 2700
MSI Carbon Pro X470
970 512Mb MVME
1Tb generic HDD
This is already a pretty high end build, so if you want to see a real upgrade difference, I would wait until the new GPUs and Ryzen CPUs later this year.
Otherwise, this would be my suggestion;
You could sell your 2070 for over £300 and then buy this, maybe even a 2080ti. Again though, I would wait till the new stuff. Also your x470 board should be fine
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
12 minutes ago, Chris Fortune said:
I like the balance but I was looking at all but GPU and will be looking at that when 3000 series settle down, budget is for the case MB CPU PSU and memory if needed
Maybe this? Unless you need pcie 4.0 there really is no point upgrading the motherboard though. Could also look at B550 when it's released in 5 days
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
TBH I am holding off on the buying spree till after the B550 boards are released but except for the case you pretty much matched my choices, I went all out on the case as my current (pre-built) on is annoying me and was looking at the 3800X rather than the 3900.
Sounds good. 3800X is definitely the more sensible option tbh
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
1 minute ago, Chris Fortune said:
How is the Phanteks for mounting water cooling, I was looking at the BeQuiet Dark 900 but it was most likely overkill for my needs
Its more an air flow focused case, one of the best. Should be good for any aio. If you want a more water cooling focused case, you could look at the Lian li o11 dynamic. It's a beautiful case, but it's a fair bit more expensive and you'll need your own fans. Have a look at Gamers Nexus' reviews on both these cases if you want more detail
PC
Ryzen 5 2600 Stock
Peripherals
LG 24MK400H
Logitech Z150
Phone
I have been looking at GN reviews, and that is part of the issue. Each time I watch one I see something I like.
Will have a look at the LianLi cases, I have heard good thing but never from at real world user.
I could easily switch back to air cooled as I don't OC much and only switched to an AIO as current case had issues, I should have changed cases tbh but it was less work to switch out CPU cooling
