Hello would like some info on positioning of fans in my mew case getting a meshify c was going to have the 3x120mm on the front pannel as intake and 2x120mm on the top as exhaust 1x120mm on the rear of the case as exhaust and i think there is a bottom fan support aswell was going to use that as intake to try and balance the pressure in the case how would this be or is there a better way to have the fan setups i would get 140mm fans but i have a lot of 120mm pwm fans already i also plan on having a 120mm aio its just broken at the moment so wws going to use push pull Would it be better mounted to the rear than the front thanks.
https://linustechtips.com/topic/1207667-case-fan-placements/
Honestly I think that is overkill. Unless you have some very power hungry components having one exhaust in the back and two intakes in the front is enough. You could throw in one extra top exhaust for good measure, but populating all the possible fans will just keep the noise levels unbearable.
https://linustechtips.com/topic/1207667-case-fan-placements/#findComment-13704281
