So I did regular maintenance on my PC yesterday, cleaning dust, reorganizing cables, and I added an internal USB receiver for my Xbox controller so I won't break it on the outside. I'm not new to PC building but I have never experienced this. Initially it was stuck in a booting loop where the gigabyte screen wouldn't even come up, then when it did boot there would be a horrible noise from my LG Ultrawide's speakers. After a swift kick it was booting fine and I gamed on it for a few hours. Then i dropped something that tapped it and the noise came back so I shut it down. It has been in a boot loop no signal ever since. It has not had any signal go to the monitor with my RTX 2070 Super so I tried my GTX 970 with no luck. This is the best I have gotten and this is no graphics card directly to the motherboard for HDMI (picture attached). I know for a fact that my x16 slot is dead so I have been using my x8 slot. Please let me know if anyone has seen this. Spec list and my current screen situation attached....
https://linustechtips.com/topic/1207617-please-help-troubleshoot/
Does it happen with the card off ?
Have you downloaded it's latest firmware and drivers ?
Ddu ?
Any OC on the GPU ?
Phone: Pixel 3a (Purple-ish).
Build Log:
Ddu ?
Any OC on the GPU ?
The picture attached is what happened without any graphics card installed and it is the farthest I got into boot.
Everything was up to date and working properly two days ago.
It doesn't boot so I can't try to run ddu to reinstall the drivers.
Also there is no overclocking on either gpu.
