After waitting and dreaming many years, finaly built the Pc I wanted for solid 1080p gaming. Tell me what you think about it! :D
- Corsair 350D
- Asus Maximus VI Gene
- i7 4770k 3.50 GHz at 3.85GHz
- EVGA GTX 780 Ti
- 16 Gb (2x8Gb) Corsair Vengeance 1600MHz
- Corsair H80i
- Corsair TX850W V.2
- Kingston 120Gb SDD
- Toshiba 2TB HD
Peripherals:
- BenQ GW2255 1080p 21,5' LED Monitor
- Corsair Vengeance K70 Mechanical Cherry MX Red Keyboard
- Corsair Vengeance M65 Mouse
Graphics + h80i:
Front: Corsair 350D with 2 AF120 High Performance fans
Monitor, Mouse & Keyboard:
Keyboard Close Up:
If anything goes wrong with the photos, they all are in my flickr account: http://www.flickr.com/photos/ricardo-ortiz-v/sets/72157641536146133/
EDIT:
Turned the PSU facing down. Now it has better air flow and a cleaner look.
https://linustechtips.com/topic/120749-first-pc-build/
not related but because you have a blower gpu like you do id turn over the psu so that its not blowing hot air into the gpu awesome build though
Specs
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1608059
I am pretty sure a PSU is supposed to suck air in with the fan and passively exhaust it.
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1608095
This will be a great idea if you are going to OC
Or this.....
CPU: i7-4770k CPU Cooler: NH-D14 RAM: Crucial Ballistix Sport 8gb GPU: EVGA Superclocked 780 ti MOBO: ASUS Maximus VI Gene PSU: Corsair RM 850 Case: Bitfenix Prodigy M
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1608099
but dosent the stock cooler for the 780ti blow out air? so then wouldnt hot air be blowing into the psu?
Specs
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1608131
I was thinking about turning the PSU fan down due the dust filter in the bottom of the case ... How much do you think this ´d help the airflow?
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1608667
Allot in my opinion more if theres sone space off the floor you will be fine
Specs
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1609085
Will you be getting a 1440p monitor? A 780 Ti is a bit overkill for 1080p.
Really nice build by the way. Love the case.
i5-4570 I CM Hyper 212 Evo I Corsair XMS3 16GB (4 x 4GB) DDR3 RAM I Asus H87M-Pro I MSI R9-280X Twin Frozr I
Plextor M5S 128GB SSD I WD Blue 500GB HDDVantec Voltra 550W I Antec GX700 Modded
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1609276
I want to but first I will try to get a 120Ghz or 144Ghz monitor. The next monitor Im specting to buy is BenQ's XL2420TE which looks awesome (
) but first I have to save money to buy something like that.
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1610387
Hope this improve air flow
sorry to inform you that you've wasted your time flipping the psu.  the psu fan sucks air into the psu and blows it out the back outside of the case.  the gpu cooler does the same exact thing.  neither of those is blowing hot air anywhere inside the case.  but now that its fan down, you can leave it.  it's really fine either way.
HP something | 5600X | Corsair  16GB | Zotac ArcticStorm GTX 1080 Ti
CaseLabs SM8 | EK Supremacy | UT60 420 | ST30 360 | ST30 240
Gentle Typhoon's and Noctua's and Noiseblocker eLoop's
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1612345
Amazing build, but I too think some of this hardware is a tad overkill for 1080p gaming. And given your choice of case (Can't wait to get mine), I would have gone with a 240mm all-in-one cooler over the H80i, for some more overclocking headroom.
Gaming PC
  • SSUPD Meshlicious White Full Mesh
  • Corsair SF650 Platinum
  • ASrock B550 Phantom Gaming ITX/ax (Won a giveaway from OptimumTech)
  • Ryzen 5 5600X w/ Scythe Big Shuriken 3
  • 2x8gb G.Skill Flare X @3200 CL14
  • PowerColor Gigabyte RX 6750 XT
  • Storage:
    • Samsung 970 Evo NVME
    • Samsung 860 Evo 2.5"
    • MyDigitalSSD BP4 250gb (mSATA inside 2.5" enclosure)
  • W11Pro
  • AOC C24G1 + Dell S2415H
  • Cheap CyerPower keyboard (Wooting 60HE coming later this year)
  • Glorious Model O Matte White
  • LTT Northern Lights DeskPad 1000mm x 500mm
  • FX Audio Dac-X6 + Monoprice Modern Retro + Fifine Studio Condenser Mic
Media Server
  • Rosewill RSV-L4412U 12-bay hotswap
  • Unraid 6.9.2
  • Asrock B450 Steel Legend
  • Ryzen 5 3600
  • 2x8gb DDR4
  • LSI 9207-8I
  • 9x 2tb IronWolf • 2x 2tb WD Red • 1x 14tb WD Shucked White Label
  • MSI GTX 1050 Ti
https://linustechtips.com/topic/120749-first-pc-build/#findComment-1612502
