aio flow rate
Solved by SolarNova,
17 minutes ago, ki8aras said:i plan on building a custom loop in the dancase a4 sfx, i was planning on using the asetek 92mm aio that fits inside the case but expanding it with an external rad so i can support a watercooled gpu
my question is: will the asetek pump have enough flow rate to support all of this?
Will it flow, yes, will it flow anything like a normal D5, not a chance. The AIO pumps have tiny impellers and dont produce much flow as it is, if u add even more restriction via a GPU block and another rad i suspect flow will drop to trickle.
Still, if have the opportunity no harm in giving it a try, worst case scenario, u have to buy a proper D5 unit anyway.
