hey guys so here is my issue
my pc is really slow and keeps freezing aswell as fortnite isnt working very well which made me look into why and what i found is
if i go into task manager it shows my gpu is running at 1% to 0% while my cpu is so much higher when in the fortnite lobby my cpu % gets to 100 and my gpu stays lower than ever, is this a problem??
my specs are
ryzen 3 3200g
rx 570 8gb
asus a320mk mobo
any help on how to fix this or if this is even a problem going onto task manager then preformance i click on my gpu everything is at 0%
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/
Task manager is not very reliable when checking GPU usage. You should probably try again with MSI Afterburner, you can see usage while in game with its overlay.
High CPU and low GPU could mean a bottleneck. What about RAM, do you have one or two sticks of memory? E.g. if you're running in single channel mode that could also be an issue.
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/#findComment-13701225
What FPS are you getting? Game lobbies tend to be very easy for the GPU to render, and if there is no frame cap, your frame rate will go through the roof. This situation will cause high CPU usage while to GPU remains relatively unused.. Use a frame rate cap or vsync to fix this.
As @Eigenvektor says, you should use something like MSI Afterburner, GPU-Z, or HWMonitor to monitor temps and usage while gaming. But assuming what you say is true...
What frame rate are you getting? What are your graphics settings? What resolution are you playing at?
I would guess that you are running at a low resolution or your settings are set very low with vsync off, and your CPU is pumping out as many frames as it can while your GPU sits mostly idle. If that is the case, you should turn up the graphics a bit.
BabyBlu.2 (Primary):
  • CPU: AMD Ryzen 5 9600X
  • Motherboard: Asus ROG STRIX B650E-F
  • RAM: G.Skill Flare X5 64GB (2x32GB) DDR5-6000 CL30 @ 6400MHz 30-40-40-96
  • GPU: MSI RTX 2080 Sea Hawk EK X, 2100MHz core, 8000MHz mem
  • Case: Phanteks Evolv X
  • Storage: XPG SX8200 Pro 2TB, 3x ADATASU800 1TB (RAID 0), Samsung 970 EVO Plus 500GB
  • PSU: Corsair HX1000i
  • Display: MSI MPG341CQR 34" 3440x1440 144Hz Freesync, Dell S2417DG 24" 2560x1440 165Hz Gsync
  • Cooling: Custom water loop (CPU & GPU), Radiators: 1x140mm(Back), 1x280mm(Top), 1x420mm(Front)
  • Keyboard: Corsair Strafe RGB (Cherry MX Brown)
  • Mouse: MasterMouse MM710
  • Headset: Corsair Void Pro RGB
  • OS: Windows 11 Pro
Roxanne (Wife Build):
  • CPU: AMD Ryzen 5 7600
  • Motherboard: Gigabyte B650I AORUS ULTRA
  • RAM: G.Skill Flare X5 32GB (2x16GB) DDR5-6000 @ 6000MHz 30-38-38-96
  • GPU: EVGA GTX 1080 FTW2 w/ LM
  • Case: Cooler Master MasterBox NR200
  • Storage: Samsung 850 EVO 250GB, Samsung 860 EVO 1TB, Silicon Power A80 2TB NVME
  • PSU: Corsair SF850L
  • Display: Dell Alienware AW3420DW GSync
  • Cooling: Arctic Liquid Freezer II 280mm
  • Keyboard: GMMK TKL(Kailh Box White)
  • Mouse: Glorious Model O-
  • Headset: SteelSeries Arctis 7
BigBox (HTPC):
  • CPU: Ryzen 5800X3D
  • Motherboard: Gigabyte B550i Aorus Pro AX
  • RAM: Corsair Vengeance LPX 2x8GB DDR4-3600 @ 3600MHz 14-14-14-28
  • GPU: MSI RTX 3080 Ventus 3X Plus OC, de-shrouded, LM TIM, replaced mem therm pads
  • Case: Fractal Design Node 202
  • Storage: SP A80 1TB, WD Black SN770 2TB
  • PSU: Corsair SF600 Gold w/ NF-A9x14
  • Display: Samsung QN90A 65" (QLED, 4K, 120Hz, HDR, VRR)
  • Cooling: Thermalright AXP-100 Copper w/ NF-A12x15
  • Keyboard/Mouse: Rii i4
  • Controllers: 4X Xbox One & 2X N64 (with USB)
  • Sound: Denon AVR S760H with 5.1.2 Atmos setup.
Harmonic (NAS/Game/Plex/Other Server):
  • CPU: Intel Core i7 6700
  • Motherboard: ASRock FATAL1TY H270M
  • RAM: 64GB DDR4-2133
  • GPU: Intel HD Graphics 530
  • Case: Fractal Design Define 7
  • HDD: 3X Seagate Exos X16 14TB in RAID 5
  • SSD: Inland Premium 512GB NVME, Sabrent 1TB NVME
  • Optical: BDXL WH14NS40 flashed to WH16NS60
  • PSU: Corsair CX450
  • Display: None
  • Cooling: Noctua NH-U14S
  • Keyboard/Mouse: None
  • 2.5Gb NIC
  • OS: Windows 10 Pro
NAS:
  • Synology DS216J
  • 2x8TB WD Red NAS HDDs in RAID 1. 8TB usable space
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/#findComment-13701252
i have a dual channel memory kit but there different sticks same brand (patriot) one is clocked at 2400mhz other 3200mhz ik it will bring them both down to 2400mhz and would it be a bottle neck from the gpu side or cpu
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/#findComment-13701342
im playing on medium settings with unlimted frams, maybe i should allow fortnite to check my system and do its own specs there is a mode where it sets the best settings for my machine and puts it on high but i turn it down should i allow fortnite to put it on high and cap the frames at 144 or lower knowing it probally wont get higher then 70 on highest settings (my monitor is 60hz anyway)
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/#findComment-13701346
looking at bench mark and doing research its a great combo with less then 9% bottle neck with high settings it gets 70-80 fps and uses about 90% gpu usage where mine is using nothing so i think this is the issue do you know how i can fix this
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/#findComment-13701354
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/#findComment-13701361
What frame rate are you actually getting.
Probably. A 60-120FPS cap might work fine.
BigBox (HTPC):
  • Display: None
  • 2.5Gb NIC
NAS:
  • Synology DS216J
https://linustechtips.com/topic/1207280-cpu-high-gpu-low/#findComment-13701405
