quick power strip question
Solved by CYBR_GHST,
Just now, Dancam38 said:when i shake the power strip i have is makes a rattling noise should i be concerned?
Yes, loose parts inside a powerstrip is never a good thing. could be a loose cable or a broken pin from one of the grounds which can lead to fatal things happening.
i'd consider changing to another one ASAP. even if you haven't had any issues so far, it can be dangerous. electricity is nothing to fool around with.
