Hello everyone,
I've got too many choices and I would like some advice from you guys.
First setup: GTX 1080Ti with an Ryzen 3 3300X, 16 GB DDR4 2133mhz = 1050 euro
Second setup: RTX 2080, AMD Ryzen 3600, 2 x 8 GB 3600mhz = 1100 euro
Third setup: 1070Ti,Ryzen 3 2200g, 8GB DDR4 2133mhz = 700 euro + complete setup (monitor, rgb keyboard, mouse)
Fourth setup: GTX 1080Ti, I7 7700K, 2 x 8 GB 2800mhz = 1175 euro
Which one should I take?
https://linustechtips.com/topic/1206763-help-with-choosing-a-setup/
#2 is the fastest I think.
#1 and #4 will run about the same speed, making the price difference amusing.
#3 is the slowest by a good bit, but is also a whole lot cheaper so that isn’t surprising.  I might take #3 over 1 or 4 as the 2400g is 4/8 just like #1 and #4, just with slower hardware.
Just now, Manchurian said:
So that leaves the 2nd and third hmm..thanks for your input.
The third setup has potential and is most probably the better value. But the ram, CPU and possibly the motherboard would have to be replaced for the computer to be balanced. As-is it would be very unbalanced an underperform.
No that is an awful combo
Much better
Decent GPU meh cpu
The imc will handle 2133 but stutters will come as you will get bad 1% lows
No
Phone: Pixel 3a (Purple-ish).
Build Log:
Just now, Adam Venckus said:
yeah i would go second however i would go with a slower GPU and faster CPU like a 2070 super with a 3700
Welcome to the forums
Why ?
For gaming the ipc difference won't make any difference it had the same imc as the 3600 and  assuming OP won't be doing anything super intensive like AVX
Build Log:
and changed the cpu and ram?
To what ?
Otherwise I will just go with the 2080.
The second build seems to be really good value
Build Log:
i have a 3600 and 5700xt and its great for gaming however its lacks in video editing and other workflow content
Just noticed you said 2070 super and not the normal 2070
My bad
Build Log:
Why ?
The only argument I can see is potential longevity. It’s a bit of a question whether even a 6/12 will be enough in the future.  It’s future though so taking a weaker gpu to get the more powerful cpu is iffy.
Yea I just noticed that it was a 2070 super
My bad I mixed up in names
I would go for the 2079 super and the 3700x
It won't have an impact on any generic performance like gaming but will certainly be better in the long run
Build Log:
Are these all prebuilt choices or is full DIY an option?
People are selling them.
Can they be changed ? Or is it a fixed unit ?
Build Log:
Then #2 if you have the cash, #3 if you want to save, ignore 1 and 4.
motherboard may matter for #2 though.  If it’s a really weak motherboard it loses a bit of ground.  Not enough, but a bit.
This is the motherboard,
Asrock Fatality B450 gaming-Itx/ac
And it has a 720 watt
That will take a bigger cpu later if needed.   720 is more power than is needed which is fine.  PSUs wear out and 720 is an odd number.  You might wind up having to replace the PSU, but that will be under $100 which still puts you well ahead of #4
For now I'm just gonna leave the setup like it is. Maybe upgrade in the future when it's really needed.
I suggest asking what that PSU unit is
For all we know it could be a non coated shitty Chinese psu
That could be a fire hazard
Build Log:
