I'm planning a build for a friend, and I need to pick out a PSU. What wattage power supply would I need to get for a single GTX 780Ti, Core i7 4770K, on a full size Z87 MB with plenty of headroom for fans and several HDDs. I would like to know what the minimum power I would need for this setup is, as I don't want them to buy a really high powered PSU if they don't need it.
Thanks
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/120675-power-supply-planning/
anything around 600w-700w will be fine
Specs
https://linustechtips.com/topic/120675-power-supply-planning/#findComment-1607124
650W good quality unit from Seasonic, Corsair...etc.
My Personal Rig - AMD 3970X | ASUS sTRX4-Pro | RTX 2080 Super | 64GB Corsair Vengeance Pro RGB DDR4 | CoolerMaster H500P Mesh
My Wife's Rig - AMD 3900X | MSI B450I Gaming | 5500 XT 4GB | 32GB Corsair Vengeance LPX DDR4-3200 | Silverstone SG13 White
https://linustechtips.com/topic/120675-power-supply-planning/#findComment-1607137
Anything around 600+ also don't get a 4770k if its just for gaming get a 4670k
Thanks for the advice :) I would have chosen that, but the person I'm building it for asked specifically for an i7 4770K (BTFOM).
https://linustechtips.com/topic/120675-power-supply-planning/#findComment-1607159
Thanks everyone, I think I'll go with a Corsair AX 860 in case they want to upgrade something down the line :)
I'm just wondering, are all the "PCIE-E cables" 6+2 pin connectors, as the Corsair website doesn't specify?
https://linustechtips.com/topic/120675-power-supply-planning/#findComment-1607197
