Budget (including currency): infinite
Country: Turkey
Games, programs or workloads that it will be used for: games
Hello! I have a Gigabyte x570 i Aorus Pro Wifi ITX board. Which big coolers will fit along with a GPU? I'm thinking about Noctua D15S or C14. I know these are compatible with the MB but specifically will they fit together with a GPU? Also, my motherboard is horizontally placed, so would a top-flow cooler like the C14 work better than a typical tower? I have two 120mm fans on top of the case. Thank you!
https://linustechtips.com/topic/1206450-air-cooler-compatibility/
Country: Turkey
What case are you using?
Hi
hi
Bitfenix Prodigy, not M, standard that is ITX only, motherboard parallel to the ground. CPU cooler clearance with 120X25 fan on top seems to be 170mm ish, according to diagram I drew based on known specs.
It'll have Noctua 200mm on front, 140mm on rear-top, and two stock 120s on the top.
Cpu cooler max. 160 mm high
graphicscaed Max. 165 mm long without drive cage max 310mm
Hi
hi
