Hey guys so ive streamed for a couple of days on streamlabs obs and ive had some settings that were okay , the stream was good looking and no stutters / fps / lag there but in game only on my monitor ingame i had some stutter issuess and i dont know why so i have decided to delete all setting and ask you guys for help to make new settings those are my pc specs and monitor and internet speed : and another thing is i also have the game im streaming capped at 80 fps since there isnt a 75 fps option
https://linustechtips.com/topic/1205870-stream-settings/
1 minute ago, Grand Laner said:
why tho? if i uncap the fps ill have 250 fps but i just cap it to 80 bec i got 75 monitor
You get tearing and stutter because your fps is too high. if you turn on vsync it should go away. Unless you need very high fps for competitive gaming then you need to live with stutters. Make sure you have newest graphics drivers.
https://linustechtips.com/topic/1205870-stream-settings/#findComment-13689458
so i should just turn on vsync?
https://linustechtips.com/topic/1205870-stream-settings/#findComment-13689463
  • 3 weeks later...
change your encoder to nvenc. do not use software x264 if you're using the same pc to play games and also stream.
all is explained here: https://stream.twitch.tv/encoding/
edit: never use vsync, uncap your framerate. unless you get unbearable screen tearing, vsync should never ever be enabled.
Edited by rikupone
https://linustechtips.com/topic/1205870-stream-settings/#findComment-13758038
