no display No display output error code d6
Solved by SuperCloneRanger,
I knew it was a long shot, the error code tells us the GPU is probably the fault, but it's always worth trying some basic and free troubleshooting steps first. I would definitely try the the GTS-250, it's something you can use to test now, if it outputs a signal you get your answer. it won't be on long enough for the paste to be an issue. Then if/when your able, you can test your system with a friends card and vise versa.
