so I have an old pc that was just collecting dust and decided to make an emulation station out of it. I want to upgrade my graphics card to a 1060 3gb wihich I have on hand from an upgrade to my workstation. but I have a problem, its an old dell which has cut down power to the pcie slot so that the max is 35w instead of 75w. as you probably relize by now this is a problem for power the card since it only has a single 6pin connector. this means that the card will only be able to draw about 110w and the tdp is 120w for a 1060 3gb plus its an asus dual oc and the bios is too locked down to limit power consumption. for a bit more refrence the power supply doesnt have a pcie 6pin connector but I am planning on using a separate psu and a dual molex to 6pin power adapter which will be able to easily supply the  75w max for a 6pin. so my question is:
what will happen if the power supply isn't outdone but the card isnt getting enough power?
https://linustechtips.com/topic/1205470-problems-powering-graphics-card/
I wouldn't recommend using the stock power supply, they're not exactly firecrackers like some PSU's but they were never meant to be used with high power gpus. I'd imagine if the GPU doesn't get enough power it clocks down. Also you don't need to change BIOS settings to limit power consumption, programs like MSI Afterburner allow you to do that pretty well.
You won’t get a display, if a card requires 75W from PCI-E then you have to have it, if you don’t it either will simply not work, you’ll get blank screen crashes, or random blue screens.
Basically if you are limited to 35W on the PCI-E then the fastest card you can possibly put in there would be a GDDR5 GT 1030 as those require only 30W to power.
Also I’m pretty sure if its a PCI-E 16x slot then the spec requires it to be 75W, manufacturers are not allowed to alter that spec in any way, shape or form. However if its an 8x slot then i’m not sure if the wattage is any different.
Quote me or @TwilightRavens if you want me to see your reply. I may go inactive for a long time from time to time because I forget how to socialize, but I will be back... eventually.
Main Gaming PC
AMD Ryzen 9 5950X || AsRock X570 Taichi || G.Skill TridentZ Neo DDR4 3600MHz 2 x 16GB C16 1.35v || AMD Wraith Prism || Phanteks Enthoo Pro E-ATX || Gigabyte RTX 3080 Ti Gaming OC || Samsung 970 Evo 250GB NVME SSD & Samsung 980 Pro 2TB NVME & Crucial 960GB SATA III SSD || EVGA Supernova 750W Platinum PQ || Windows 10 Pro 22H2 x64 || Gigabyte M27Q 27" 170Hz 1440P & Acer 21.5” 1080p 75hz IPS || Logitech G213 Prodigy || Logitech G502 Hero
Laptop
AMD Ryzen 5 4600H with RadeonGraphics || ASUS TUF A15 ||  DDR4 3200MHz 2 x 8GB C22 1.2v || ASUS GeForce GTX 1650 4G GDDR6 || 512GB NVME M.2 SSD  ||  Ubuntu 22.04.1 (Jammy Jellyfish)
the problem is Im running manjaro and afterburner is windows only right? because I really dont need it to be running at full capacity. as long as it isnt the hd6450 1GB card that is in it right now
There are guides out there that should help you modify the power limit. I'll leave some articles below
https://forum.level1techs.com/t/how-to-set-nvidia-gpu-power-limit-nvidia-smi/131467/2
https://gist.github.com/abelardojarab/c2eea9d72342f7ade381c929edeb83fc
I don’t think they clock down if they don’t receive enough power, or at least in my case they don’t. I had a LGA 775 build with an overclocked QX9650 4GHz (basically consumed way north of 300W under load) and a R9 290X (which at stock is a 295W card) and a 600W 80+ psu and whenever it would exceed the 600W it would trip ocp on the psu and just restart the system, it worked fine other than that but its not fun having a random reboot in the middle of a game. Though this I’m not sure what will happen as mine was from a too low of wattage PSU rater than a PCI-E slot rated for 35W, but if I had to guess the same thing in theory would happen.
Main Gaming PC
Laptop
Thank you so much! I get this isnt a definite fix but if this doesnt work I can do no more
I'll keep it in mind Im thankfull for every reply!
I mean it won’t hurt anything to try it as is, worst case like i said would be (since you are on linux) would be either a kernel panic, random reboot, black screen crash or it’ll work fine, if the former happens then the best you can do is trying to enforcing a stricter power limit like stated above, though that’s what you’d be limited to since you can’t mod NVIDIA’s Pascal bios directly like you could with Maxwell and earlier cards.
Main Gaming PC
Laptop
