Its my first build and I've been following the documentation + LTT videos on how to build a PC
There's no power when I push the the button
PS: MB is Zen 2 Ready
I think everything is plugged correctly? Cable managment not done since it does not start.
CPU: Ryzen 5 3600 @ 4.4GHz 1.2v / GPU: MSI Radeon RX 5700 Mech OC GP (5700XT Bios) @ 2GHz / MB: Asus ROG Strix B450-F / RAM: Kingston HyperX 16GB DDR4 3200MHz CL16 / CASE: MSI MAG Vampiric 010X
https://linustechtips.com/topic/1204081-pc-does-not-power-up/
Check the switch on the back of the psu, check the front panel I/o making sure they are in the right places. If not try unplugging a ram stick then booting. Also try resetting cmos. Also I see that you put the ram stick in slot 1 and 4. They have to be spaced out 1 slot so that means 2 and 4
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674613
are you getting any sign of life on the mobo or ram? e.g: if you have any rgb is it on? are the fans running? Make sure you connect the front panel io and turn the power on at the psu switch.
                                               JOIN THE FIGHT AGAINST COVID-19 BY RUNNING FOLDING AT HOME!!
        have a look at the thread below if your interested:
Home gaming and general work rig: CPU: 2700x with stock cooler Ram: Corsair vengeance pro RGB 16gb GPU: RX570 4GB (upgrading soon) Storage: 1x 500gb crucial SSD + 1tb HDD Mobo: B450-F gaming PSU: Corsair rmx550Case: Corsair 275R
F@H rig (In office and used for work too) CPU: 3600 Ram: Viper 16gb ram Mobo: B550-Tomahawk GPU's 1x 2080 super 1x 2060 super Storage: SN750 1tb Case: PC 011 Air PSU: Corsair RM850 Fans: 6x Noctua NF-12
Remember to quote me so I can see your reply!
Always Reply with a question if you have one! 😃
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674630
the ram is in 2 and 4 in the photo.
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674632
PSU Switch is on
No, No fans spin, no RGB light, nothing.
Front Panel io already done 4 times following the Motherboard documentation and i dont know if im doing it wrong.
photo5960549497811612811.thumb.jpg.9a7ab5b15f827afb830600c0413553ab.jpgphoto5960549497811612828.jpg.cfe81ead789c1708a93d724ec92668fb.jpg
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674641
5 minutes ago, LordWk said:
PSU Switch is on
i would now make sure you have all the psu connectors plugged in properly like the 8-pin cpu and 24pin mobo.
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674649
PSU Switch is on
It looks like the power switch wire is in the first header  instead of the second one. Try moving it over one
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674657
Yeah it was a wrong picture, its alread on its place.
The MB I have plugged the one on the MB and the one on the PSU, but in the same cable there is 8pins that im not using, are those the problem or what?
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674662
@LordWk
You're front panel is not hooked up correctly . I don't know how no one else knows it's wrong with multiple pictures of it.
You have your Power Switch connector where the Power LED connectors go.
Your PLED+ is the far left and PLED - right next to it, they go where you have the Power Switch connector now and the Power Switch connector goes directly above where you have the Reset Switch.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674664
i've just looked at my mobo ( have the same one) and the io ins't plugged in properly i dont think
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674667
I also realized that @LordWk move the powersw connector one to the right and you powerled’s to where your powersw was
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674672
All front panel connectors should be on the left side of the front panel header, look at the motherboard manuals diagram again. PLED on the top left, Power Switch on top right, HDD LED on bottom left and Reset Switch bottom right, all connectors should be on the left hand side of the front panel header and should form a rectangle when all together.
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674685
22 minutes ago, SpookyCitrus said:
@LordWk
Still no power
In the first post there is where i plugged everything and how the back of the PSU looks, it could be something of that?
88f0f979-4dbe-475f-af6f-2eaca1831098.jpg.a63bb95a37db2babb51c5c4fe090b789.jpgphoto5960549497811612840.jpg
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674706
11 minutes ago, LordWk said:
Still no power
The front panel is correct in that picture, if you have the PSU hooked up correctly once you plug it into the wall and turn the PSU power switch to on(the I not 0) the ROG logo on the motherboard should light up indicating that you have power. If it doesn't then you know the PSU is not properly hooked up.
Is the ROG logo in the top left of the motherboard lighting up when you plug the computer into the wall and flip the power switch?
What is the brand and model of the PSU you have?
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674759
nvm it was a power cable for the mb that was separated and not plugged in, it works!!! thanks anyway it woulnd work without your advice on the front panel!!
https://linustechtips.com/topic/1204081-pc-does-not-power-up/#findComment-13674795
