just today i have built my pc up from scrach because of buing mostly new parts and after i started it up and went inot bios to change to the xmp setiing it was all ok, untill i checked my ram usage on the task manager, when i look into it i see that there is indeed 16 gb of memory installed but 8,5gb of it is hardware reserved, it was my first time building a pc so i don't know if i did something wrong, please help me if you can.
my specs:
Motherboard: Msi gaming plus max
cpu: ryzen 5 3600
ram: Corsair DDR4 Vengeance LPX 2x8GB 3200 C16
psu: Seasonic Core Gold GC 650
ssd: Samsung 970 EVO 500GB M.2 SSD
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/
Reseat the memory (take it out of the motherboard and re-insert it).
Make sure the RAM is in slots 2 and 4 (counting from the left side/CPU socket side)
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672116
did that, didin't help. ram is still at 16 but hardware reserved is 8,5, same as picture above
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672142
I went into the BIOS and tried disabling the xmp and now when I try to start my system I keep getting blue screen
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672156
Try memory stick #1 in slot two. Does it work (with XMP and in Windows)? Great.
Now take memory stick #1 out and do the same with memory stick #2 in slot two.
I kind of have a feeling one of the sticks is acting up.
You could try updating the motherboard BIOS too, maybe there was a RAM issue with the current version
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672169
Update: it keeps trying to automatically repair but after that it boots and goes into a blue screen again, right now it's stuck at attempting repairs, haven't tried taking out the memory yet and trying it in slot 2
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672186
Tried putting stick #1 and 2 in slot 2 but both keep getting blue screen saying bad system config info
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672278
Sounds like your RAM is really acting up in this case.
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672323
I believe that, tried turning xmp on and off on both 1x8 and 2x8 config, none will work pc keeps getting blue screen, it all started when I turned off the xmp first time with both rams in the slots, could I have broken them or something like that ?
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672330
In the past I have had issue with Corsair+AMD boards, but that was mainly with enabling the XMP profile.
Sounds like a memory problem though
Shouldn't my dram led light up if it would be my ram problem ?
That's mainly for if it found memory issues during startup; but necessarily for when you're booting into Windows.
But of course I can't say it's not  motherboard problem
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672341
Everything booted up properly the first time I started it, changed the xmp to enabled and it was still working properly, tried to disable the xmp to maybe fix the problem of ram on hardware reserved and that broke it down, I keep getting blue screens and can't get into windows at all, I also don't have any other ddr4 memory laying around only an 8gb stick of old ddr3 so I can't check if that is the problem.  Should I try to flash the BIOS when I wake up tomorrow ?
https://linustechtips.com/topic/1203747-help-with-ddr4-memory/#findComment-13672356
