So I just got a new case was all excited and come to find out one of my front panel connectors says LED SW which I assume is Led switch and there is an RGB controller in the case it's a gamdias case but the header on my motherboard does not support this option so trying to bypass this issue would I be able to hook up the leads for the LED switch to a 12 volt power likes a Molex connector would that give me what I need to power the switch keep in mind that the controller is already powered and I'm not really sure why there is a need for it to go to the motherboard and the fan speed control switch works fine so I know at least that part of the controller is working
https://linustechtips.com/topic/1203611-led-sw-fpc/
Deleted.  Non topical
https://linustechtips.com/topic/1203611-led-sw-fpc/#findComment-13671110
