Budget (including currency): around 1200 usd
Country: america
Games, programs or workloads that it will be used for: fortnite, cod warzone, gta 5, rdr2, r6, forza 4, metro exodus
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): 1080p 144hz over 100 fps
thaks,
Alfonso Cornwall the 2nd.
edit: changed to 1080p
https://linustechtips.com/topic/1203571-first-build-help/
I've just installed both the Western Digital SN750 500GB (/w Heatsink) and SN550 1TB in my PC.
They are regularly discounted and I'd recommend them over the Crucial P1.
https://shop.westerndigital.com/products/internal-drives/wd-blue-sn550-nvme-ssd#WDS500G2B0C
https://linustechtips.com/topic/1203571-first-build-help/#findComment-13670716
