General rule of thumb anything under 70 regardess of processor (excluding servers) and your fine.
In this case based on the below,
https://forums.hexus.net/cpus/383681-i7-8700k-average-temps.html
idle ave = 40
max on stress test = 80-85
Hope this helps put your mind at rest.
https://linustechtips.com/topic/1202872-how-are-my-temps/#findComment-13665030
idle ave = 40
Yeah it does thank you looking at some reviews and some of the posts in that forum (like the guy who said he gets 75c) my temps seem to be fine if not on the better side. And hey if something does go wrong I can get a replacement or upgrade to a 360mm but that might not make much do no difference in performance. Also my case is average for airflow (h700i)
https://linustechtips.com/topic/1202872-how-are-my-temps/#findComment-13665076
