My specs are a ROG Strix b450 f gaming, ryzen 9 3900, hyper x fury 2x8gb, psu 600 bq 80 plus, msi rx570. My pc has been working fine for over a year now and i exchanged the cpu from ryzen 5 2600 to a ryzen 9 3900 today. I also added a ssd kingston 480gb. The mobo has some lights that identify which part of it is not functioning and it shows the dram. I 've tried taking them out and move from slot to slot mutiple times and it still remains lit. And another problem is that i can't see the screen despite the gpu or cpu not being the problem according to the mobo lights. I really need some help with this cause if its the motherboard, i'm in deep hell.
https://linustechtips.com/topic/1202821-ram-problems/
Did you update the bios before you exchanged the CPU to the 3900?
Current Build
AMD Ryzen 2600
Stock cooler
Asus ROG B450f gaming Mobo
1tb SKHynix m.2
WD 1TB HDD
Asus ROG Strix RX 5700xt
Thermaltake Toughpower 650w DPS RGB 80+Gold
16 Gigs ddr4 3000 gskill ram
Phantek fans
Phanteks P400TG
Laptop
Eluktronics Prometheus XVII
Ryzen 7 5800h
32 gigs ddr4 Corsair ram
Nvidia rtx 3080 max-p
17.3 qhd 165 hrz screen
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1202821-ram-problems/#findComment-13665257
4 hours ago, Mando9854 said:
i updated my BIOS and it's working fine now. Thanks a lot!
Glad to hear it. Enjoy the nice upgrade.
Current Build
AMD Ryzen 2600
Stock cooler
1tb SKHynix m.2
WD 1TB HDD
Phantek fans
Phanteks P400TG
Laptop
Ryzen 7 5800h
1tb Samsung m.2
1tb WD black m.2
https://linustechtips.com/topic/1202821-ram-problems/#findComment-13676308
