Energy efficient GPU for transcoding/watching streams
I'm planning a  NAS/VM Host/Plex server build based on an AMD platform.  Currently I ponder about what would be the best GPU choice, the CPU will have at least 8 cores that means iGPUs are off the table. I will attach a TV or monitor directly to the server via HDMI or DP for TV/Movie steaming only. There will be absolutely no gaming or video editing going on on that machine. So basically the GPU needs to excel in the following areas:
  • Very low power consumption (especially when idle)
  • H.264, VP-9, WMV tanscoding capabilites (for Plex)
  • in expensive (this will be a low end GPU so it should not come in at a premium price tag, everything I can save on the GPU will go towards more and/or faster storage)
Used 750Ti?
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
6 minutes ago, Mateyyy said:
Used 750Ti?
This is one of the options that comes to mind but what would be the advantage of a 750 Ti over a GT 710 for instance? I'm especially considering the GT 1030 because it has hardware support for VP9 encoding. But I'm not sure if there is another VP9-capable card that is suited better for my build.
https://developer.nvidia.com/video-encode-decode-gpu-support-matrix
So, according to Nvidia, the GTX 750 (non-Ti) and 950 support 8-bit VP9 encoding, as they're both 2nd gen Maxwell. Other than that, the 1030 would probably suit your needs.
