Hi, I need help to figure out why my pc is having fps drop from 60 to 30 sometimes 20 it happened after changing my monitor from 75hz hd 24 inch to 165hz fhd 27 inch. I already updated the drivers and scanned for viruses.My computer specs,
Mobo: Msi b450m bazooka
Cpu: Ryzen 5 2600
Ram:  corsair vengeance 16gb
Gpu: msi gaming z Rtx 2060 6 gb
Psu: 450 watts evga bronze
Cooler: corsair h60
Hdd: 2 tb toshiba
Ssd: 250gb western digital green
Case fans: 3
Old monitor: asus vg245h 75hz 1 ms 24 inch
New monitor: msi optix mag247r 1 ms 165 hz 27 inch hdr ready 1500r curve
I suspect the psu can't deliver enough power  both cpu and gpu and I do really appreciate the advice 🙏 👍
Edited by MichaelR1497
Added more information
https://linustechtips.com/topic/1202471-help-pls-fps-drop/
If this was the case, then the system would power off entirely. 450 W is tight but adequate.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1202471-help-pls-fps-drop/#findComment-13662023
Can it cause instability in power between the gpu and the cpu that results in fps drop since my 450 watts psu is a tight fit here?
https://linustechtips.com/topic/1202471-help-pls-fps-drop/#findComment-13662045
Only if it's a cheap no-name unit with no overcurrent protection.
https://linustechtips.com/topic/1202471-help-pls-fps-drop/#findComment-13662049
2 minutes ago, narrdarr said:
have you done any monitoring of the cpu or gpu? temps, and clocks
do you know what your ram is set too?
do you have the latest bios that supports your cpu?
Yes I do have a monitor software
My cpu idles between 35 to 40c when I'm playing it goes 60c, my gpu also goes 60c when under load.
My ram is set to 2400mhz standard
Yes I also updated my bios, and No I haven't done any overclocking.
https://linustechtips.com/topic/1202471-help-pls-fps-drop/#findComment-13662069
18 hours ago, narrdarr said:
Do you know the utilization of your cpu and gpu?
Do you know what your ram speed is rated for?
getting 2933mhz will help alot
My ram speed is 2400 and I think but I'm not sure I can't overclock it
For my CPU and GPU, I'll check the utilization however I also did a benchmark my cpu score degraded when my monitor was on g sync but when I turned it off my benchmark increased.
https://linustechtips.com/topic/1202471-help-pls-fps-drop/#findComment-13664303
