should be able to buy a hdmi or dp to dvi cable for pretty cheap. If your monitor only has dvi you may want to upgrade to something more expensive if your pairing it with a very solid mid-range card like the 2060 to get the best experience
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1201274-rtx-2060-help/#findComment-13652781
6 minutes ago, Jack Sproston said:
I want to buy an RTX 2060 but my monitor only has a DVI port where as the card only has DP and HDMI is there a way i can make it work??
BENFEI DisplayPort to DVI Adapter, Dp Display Port to DVI Converter Male to Male Gold-Plated Cord 6 Feet Black Cable for Lenovo, Dell, HP and Other Brand https://www.amazon.com/dp/B01GPMRXL0/ref=cm_sw_r_cp_api_i_Rk-ZEb17C5NAC
https://linustechtips.com/topic/1201274-rtx-2060-help/#findComment-13652784
