Hello,
A few days ago I did an update on my Bios. Previously my 8600k would run stable @4.8Ghz with 1.3V...Since the update my CPU clock speed drops after startup with the same settings as before (I can see that it is at the beginning @4.8GHz) but then drops to 4.1GHz..I tried to set EIST off and also windows power management settings. Nothing works. Has anyone else experienced this problem aswell? Bios shows "correct" speed but taskmanager and CPU-Z both show 4.1GHZ
Motherboars: MSI Z370 Gaming Pro Carbon, latest Bios
8600k
32GB 3200Mhz CL14 Gskill Trident Z Memory
https://linustechtips.com/topic/1200467-oc-cpu-clock-speed-drops-after-startup/
5 minutes ago, GerhardP said:
Hello,
8600k
Did you check your BIOS settings? BIOS updates will revert all settings back to factory defaults.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
